Sjotroll
Geotechnical
- Jan 2, 2018
- 29
Hello!
When designing a concrete gravity wall against sliding, overturning and bearing capacity in a seismic design situation by using a pseudo-static analysis, do you take into account the inertial force of the wall, expressed as F[sub]i[/sub]=W*k (where F[sub]i[/sub] - inertial force, W - wall self weight, k - horizontal coefficient of seismic acceleration)?
In every book I look, they explain the pressure the earth exerts on the wall, but they don't talk about the design of the wall after we defined the soil forces on the wall. For example, by using the Mononobe-Okabe method we take into account the inertial forces of the backfill, and that is all contained into the P[sub]AE[/sub] force, but do we need to take the inertial force of the wall for the stability check?
Also, my question refers to making the design on the basis of stresses. In the other design method, where the design is based on allowable deformations, the inertial force of the wall is taken into account because it's needed to define the allowable ground acceleration.
As far as I remember, during classes in my faculty we never took the inertial force of the wall, but I found sources which take it.
What are your experiences regarding the subject?
