I have experienced the use of a -20deg lithium based grease at low temperatures (about -15deg)and there was evidence of solidification and crytals present. The grease is used to lubriacate seawater seals and led to the seals passing. Does anyone know if the grease expands or contracts at lower temperatures?
The grease properties are as follows:
Drop point 180degC
Base Oil Viscosity 150cSt @ 40degC
Penetration 265-295 (N.L.G.No.2)
Drop point 180degC
