ForeverStudent
Dear Members,
Model plumbing codes require indirect piping (air gap) when connecting food handling fixtures to the plumbing system. Typical arrangement for restaurants is: triple sink - grease trap - plumbing system. My question is - where it is preferable to put an air gap - upstream or downstream of grease trap. I saw recommendations to do it immediately after sink (which means upstream), but I doubt if it is going to work, because typical grease trap has flow control fitting upstream. Is it regulated by code?
Any suggestions?
Thank you very much in advance!
Any suggestions?
