liam1369
- Nov 13, 2014
- 73
Good evening all,
I have a general query for a detail I am developing and this is for the interaction between a ground bearing slab edge thickening, which is going to be supporting masonry and a pile cap which is supporting a steel column.
Most general details (see attached a couple of examples) show the ground edge beam thickening sitting directly on top of the pile cap / pad where applicable? I would have thought it would be more beneficial to allow for a similar build up below the slab edge thickening before the pile cap / pad starts. As opposed to casting the new ground slab edge thickening directly on top of it?
In addition, between the caps / pads the edge thickening will be on compacted stone and wherever there is a pad/cap the edge thickening will be on the pad/cap. Surely this will effect the deflection, at least theoretically.
Does anyone else have a similar view from a general detailing view? I currently think the top of the pile cap / pad should stool down around 500mm below the bottom of the edge thickening before the top of the cap/pad starts.
Please see attachments for clarification.
Many thanks all,
Liam
Many thanks all,
Liam
