Grounding Disconnect Switch
tin2779
38
I was wondering about a practice followed by Utilities of using a disconnet switch to disconnet two grounding grids. I tried many vendors but no success.Could you kindly advise.
I have two grounding grids, one of them is under construction and another is an existing remote grid. I want to have a switch which can disconnnet two grids for resistance measurement.
Why to use disconnector switch? It is more easy to use a manhole where bars from both grids may be joined or disconnected.
It may be like this in theory and practice, but in real life it is completely different.
The favourite sentence of my army sergeant
Thanks Lz. A manhole is a goood idea but how do I disconnect them. If I use a compression connector or a cad weld connection, it is a new headche when ever a independent measurement needs to be done.
I read some where that Utilities have the leverage of using a switch but I am not sure about industrial installations.
So any thing except a permanent connection ?
