burntcoil
- Sep 28, 2011
- 75
While carrying out the calculation for Substation Grouding Grid as per IEEE Std. 80, I found that in most of the example Breaker Short Circuit withstand rating is used for single phase to ground fault current. For a substation where I have MV switchgear with Circuit Breaker rating of 31.5kA rated and LV Switchgear with 65kA rated circuit breaker, which short circuit rating value I will choose, 31.5kA or 65kA.
In the example I saw they are considering 31.5kA (or short circuit of MV Breakers). This makes me think that the MV network is normally three phase three wire and LV network is 3 phase 4 wire and the neutral is grounded. So why do we consider MV breaker short circuit withstand value.
Further to above, the single line to ground fault value will always be much less then the Circuit Breaker short time withstand, why we do not consider actual single line to ground fault current while following IEEE Std. 80-2000.
