lorenolepi
Aerospace
Is there a way to group components for a component array without making them a sub-assembly?
Example of what I'm trying to do...
In a tooling fixture we will have a base plate and a set of eight clamps...each clamp will have a screw and a set screw. (all components are from the re-use library) but they are not a sub-assy. The base plate has one threaded hole that is instanced arrayed eight times for the srew that holds down the clamp.
I really like to use the componet array using the "from instance feature" for the array deffinition because of the way it will atuomatically update when the number of holes change, instead of the circular array that needs to updated manually. The issue is that to have three components constrained to the one instance hole is some what of pain, because only the screw really lines up with it.
I was hoping that there would be a way like feature grouping. Where you could group the features and then do an array on the feaure group. I have tried to use the component group but it doesn't appear to allow me to select it when I choose component array.
Any input would be greatly appreciated!
