  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Guard Rail 1
trsidn
11
0
0
Can anyone tell me the requirements for where a guard rail is required, or where I can find this information?
In United States, AASHTO would probably set the standard. otherwise, USDOT. Check with your local highway department
The AASHTO Roadside Design Guide is pretty much the basis for most states. For low volume roads (<400 vpd), the AASHTO Geometric Guidelines for Very Low Volume Roads is a bit more realistic.
The RDG is available at Also, check yopur state's DOT website and look for their highway design manual.
In the UK British Standard BS 5400 Design code for bridges gives the design criteria for pridge parapets and barriers under vehicular impact load.
