Guidance on selecting a Pressure Safety Valve (PSV) from API 526 "Valve Size" column 1
samuel-1
Chemical
Jul 19, 2024
I am reaching out to seek guidance on manually selecting a Pressure Safety Valve (PSV) from API 526 "Valve
Size"
column.
Here are the details of my scenario:
- **Operating Pressure:** 122.7 barg
- **Operating Temperature:** 29.2°C
- **Set Pressure:** 240 barg
- **Relieving Pressure:** 290.4 barg (fire case)
- **Relieving Temperature:** 244.2°C (fire case)
- **Valve Type:** Carbon steel, pilot-operated valve with orifice type D (Effective Orifice Area = 0.307 in²)
I am particularly confused about the use of Table 17 in API 526. It mentions “Inlet Flange (Set) Pressure Limit,” and I am unsure whether the relieving temperature and corresponding pressure should be considered when choosing the PSV.
I need clarity on this matter.
Thank you for your time and assistance.
You should use the valve Set Pressure and incidental Relief Temperature. However, you should also ensure that the selected size/ratings parameters are also suitable for your design/extreme - pressure/temperatures (not normally the fire case temp).
What API-526 does not inform, is the pressure ratings in between the stated temperatures.
You are best to actually use the manufacturers catalogues which show the ratings graphically - note manufacturers ratings may be different to API-526 dependent on their design.
Your conditions normally require a Class 2500 inlet (F orifice) x Class 300 Outlet (if carbon steel) - 1" x F x 2" or 1.1/2" x F x 2" can be used
Note your orifice size stated as 0.307in2 is a 'F' orifice not 'D'.
Also consider what elastomers are to be used at your high temperatures.
Question: What is reason to select pilot operated and not spring operated? Spring selection would need to be 1.1/2" F x 3" size.
My advise. Select your vendor and talk to them.
*** Per ISO-4126, the generic term
'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
Thank you Obturator,
I truly appreciate
Yes you are right the Effective Orifice Area of D” Orifice = 0.110 in.2 (I was only talking about 'D' orifice table 17, but mistakenly pulled information from another table). My spreadsheet selected 1.1/2" x D x 2", but I really wanted to know why (and not rely too much on softwares/spreadsheets)
ok so if I understand you correctly, I would select the "Valve Size" column, based on a Set Pressure of 240 barg and temperature of 244.2°C, while ensuring that the selected size/ratings parameters are also suitable for my extreme temperatures.
Re: So I am on a project and the client wanted a pilot PSV (because its relieving mass flow = rated mass flow) in other to optimise the size of the maintenance KO drum & flare stack (The client wants it to be as small as possible. Infact the KO drum is mobile & would be hooked up when needed for maintenance, as the facility is fully rated.)
[COLOR=]At the present stage of the project, Client & EPC is yet to engage the vendors.[/color]
Thank you once again.
You followed my notes well. You say that a pilot is selected for the PSV to be as small as possible. At these sizes D - F most designs are not much smaller than their spring counterparts - some manufacturers designs are even bigger! Personally, I would be offering a spring loaded design which is much more economic at that size and the maintenance much less due to the robustness of a spring loaded design.
Firecase relieving temp is only relevant to selection of orifice size. Use the process-mechanical upper design temp for selection of flange rating for all nozzles.
