I'm having a discussion with other people at my company on how much load a continuous wire rope can hold.
Example:
A continuous wire rope is threaded thru a pulley attached to a pole. They are attached at the ground at the same point. For a load of, say 4000#, each leg takes 2000#. The rated breaking strength of the wire rope is 4000#.
Question: Since each leg is taking one-half of the load, can the 4000# load be increased to 8000#. Is the tension at the point of contact with the top of the pulley 4000# or 8000#, thereby exceeding the rated breaking stength.
Also, will the shear at this point be 4000# or 8000#.
Thank you for your help.
Example:
