hocho
- Aug 26, 2015
- 98
In walls perpendicular to the seismic direction.. do you use the full height of the wall in computing for the seismic weight or one half of height only.. and what is the basis for half height only as some do?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hocho said:So there is basis that when walls are more flexible, there is less acceleration due to some energy being dissipated in the flexure?
There's some merit to this logically. If your wall was a bowling ball suspended from rubber bands above and below it probably wouldn't draw any seismic load at all. As a practical design strategy, however, I feel that this "flexible wall" business is fundamentally flawed. No common wall assembly would be anywhere Near flexible enough for this strategy to bear fruit. In essence, all walls accelerate the same amount as the floors they're attached to.
hocho said:You make sense as always.
Extending existing concrete is a common problem. Depending on available funds and labor, there are a number options (you've already mentioned most):
1) Chip and splice with mechanical couplers.
2) Chip and splice with bar to bar welds.
3) Chip and splice bar to plate to bar with welds.
4) External steel plating as you've suggested.
5) Sister a new wall beside the existing wall and connect the two.
6) Drill and epoxy new dowels into place and either rely on concrete in tension breakout or effectively lap the new bars with the old.
7) Demo the existing wall and start anew.
As a first step, I'd evaluate the existing wall/slab joint for the new wind and seismic moments. A 7", 3m high cantilever wall with one curtain of light rebar might be a problem if you're in a high seismic or hurricane prone region.
The most common block wall here seems to be 8" with 15M at 48" o/c. Each wall is custom designed to suit it's span and loading, however, so there is considerable variation.
15M is metric rebar about 16 mm in diameter. Our block looks like yours but is generally fabricated in 16 in modules.
That's exactly how most of our block walls go together. ACI 530 gives formulae for strength design of masonry. It is very similar in concept to concrete design.
This is essentially a cantilevered wall system and all of the wall seismic mass would be transferred to the floor diaphragm below. You'd also wind up with seismic moments being applied to the floor diaphragm as well. In my market, a screen wall like this would probably be concrete if it were to be installed on top of an otherwise concrete building. Maybe steel post and girts if aesthetic concerns were minimal.
A wall that spans from a diaphragm above to a diaphragm below can be, and usually is, modelled as pinned top and bottom for the purpose of diaphragm design. A cantilevered wall, on the other hand, must generally deliver its base moment as:
1) torsion in the supporting beam,
2) flexure in the slab below or;
3) flexure in the wall below if such a wall is present.
That's all that I was getting at with my previous comment.
hocho said:therefore roof diaphragm would be also for the benefit the lateral force resisting system?
