mrmalcolm
Marine/Ocean
- Jan 24, 2024
- 39
For the tensile test of steel, tensile specimen with the full product thickness should be performed.
Particularly on very thick products where the capacity of the available testing machine is insufficient to allow the use of test specimen of full thickness, this may be reduced by machining one of the rolled surfaces.Alternatively, proportional round test specimens may be used.
Can the tensile properties of a half thickness specimen represent the tensile properties of a product. What is the relationship between the tensile properties of a half thickness tensile specimen retaining one rolled surface and the tensile properties of a full thickness specimen. What is the relationship between the tensile properties of proportional round test specimen and the tensile properties of a full thickness specimen. Do you have any relevant literature or data recommendations? Thank you
