Ittichet
- Apr 4, 2015
- 8
Hi, I working on HRSG Fabrication with 9 Cr material, I have customer specification state that "If the assembly is not PWHT within 24 hours of the completion of welding, it shall be enclosed or covered and be stored 5 degrees above ambient temperature" I wonder what is the reason to store work piece at 5 degrees above ambient temperature? Also, spec require to Hold at 200 F for minimum 1 hrs before PWHT, What's the reason for that? Is all of this for allow hydrogen escape and keep hydrogen (Humid) away from weld?
Thanks for all answer.
Pook
Pook
