SgtYui
- May 22, 2015
- 13
Does anyone have any good resources on designing pipe supports as anchor points in hot run of pipe? The sketch I have attached is something I've heard works for redirecting the torsion created from the pipe's expansion and the offset of the pipe center line and center of the wide flange beam. I've been told that the channel is much stiffer from a load in the indicated direction and will help reduce torsional forces the wide flange sees during thermal expansion/contraction. Any guidance would be appreciated.
