SPruitt
- Dec 9, 2016
- 15
I am designing a stair system in a building where the intermediate landings are being supported off the overhead steel structure at 3 of the 4 corners. Right now, the detailer shows one of the back corners supported off a seat on a structural column, but is using hanger rods for the other three corners of the landing. Usually, I would add columns where I can or support off the walls, but I can only do this at the first intermediate landing and not at the upper floor landings. If I need to use hangers on 3 of the 4 sides, do I need to be worried about the stability of the structure? I cannot find anything about lateral loading on stairs (other than seismic loading, which I do not have to consider), but I'm wondering if I need to worry about any type of sway due to the flexibility of the hanging rods. The stairs are connected to main structural members at the floor levels. Any insight is appreciated.
