angelo_HVAC
I’ve been trying to work with HAP v6 for awhile now and i keep coming across the obstacles below :
1.Partitions.
When adding partition walls for certain spaces , towards the assembly section , there’s another option that shows up as interior walls but under the external wall section. (?)
2 . Alternatives : How do I preview the design report if my project involves a District cooling plant? and not chillers.
3.While adding the windows in the opening section , i have to remove 50-60mm of the actual window length to place the window. I can never place the actual size.
3. Lastly while trying to view the design results , an error is displayed which I’ve not experienced before (see image)
Any advice would be much appreciated .
1.Partitions.
