SA07
- Feb 22, 2018
- 372
Hi
We have 2 boilers using coal or bagasse as fuel. There is a hardwire circuit using relays to stop boiler coal or bagasse feeders and close the gate valves. There is emergency push button boiler in Control Room and a Digital Output from Boiler PLC which open this circuit.
In the past, we have got several boiler trips following disturbance/faults on the utility network. We suspect this hardwire circuit is cause of the trips. There is 24 Vdc power supply.
Is it possible to suppress this hard wire and do all the programming in the boiler PLC for the fuel feeders?
We have other critical boiler safety like the following which are programmed in the boiler PLC.
deaerator low water level
drum low or high level
main steam pressure high
furnace pressure high or low
SA, FD, ID fan stop
SA, FD, ID fan stop
