I am working on a project for a client where we have turned a cylinder (AL 6061-T6) to a certain diameter ~2" and must have it "black hardcoat anodize, teflon impregnate, .0008/.0010 thick buildup". We do not do the hardcoat anodizing (Type III, Class 2) or teflon coating in house.
The first batch we made and had coated passed inspection perfectly. The second batch has had an ~50% rejection due to discoloration of the hardcoat in certain areas. These areas look like dried puddles - concentric rings of varying offset located in a random pattern on some of the pieces. We spoke to the anodizer who walked us through his process showing that there is no time where the pieces are placed on a surface that might cause this discoloration. They told us that the discoloration is due to the grain within the AL and that it was created that way at the mill. They said they have seen this before where this grain structure (like a knot in a piece of wood) runs entirely through a piece and other times where it is only surface marring.
I have added a photo that somewhat shows this pattern.
Any thoughts or explanation on this issue would be greatly appreciated as the pieces are being rejected for cosmetic reasons only - no structural or functional flaws.
Thank you for your time.
Aidan
Aidan
