Everything you wanted to know about Electroless Nickel (well, almost):
ASTM specs. are available from ASTM (
for about $35 each, AMS specs. are from SAE (
for $59, MIL specs. are available on the Defence Department's ASSIST site (
for free, but certain specs. are 'Controlled Distribution Document,' including MIL-DTL-26074F & MIL-C-26074E.
Here is a good, brief introduction to Electroless Nickel:
The Metal Finishing Guidebook explains the electroless reaction, gives solution formulas, deposit properties, etc.:
"EN Specifications: Working Tools for Industry" is at
This article presents a portion of ASTM B733 relating to heat treatment of EN-plated parts:
Post Treatment. Classes of post heat treatment:
Class 1: As deposited
Class 2: 850 Knoop hardness minimum
Class 3: Heat treat at 180 to 200C for two to four hours to improve adhesion and provide hydrogen embrittlement relief.
Class 4: Heat treat at 120 to 130C for at least one hour to improve adhesion on heat-treatable aluminum alloys and carburized steel
Class 5: Heat treat at 140 to 150C for at least one hour to improve adhesion for non-age-hardened aluminum and beryllium alloys
From MIL-C-26074,
The required hardness for Class 2 can be achieved by heating according to any of the following schedules:
Temperature (F) Hours
500 4 or more
550 2 or more
650 1 to 1.5
750 0.5 to 1
[I prefer 500 or 550 F; higher temps cause tarnish in air.]
"Physical Properties of Electroless Nickel -Phosphorous Deposits" including hardness & Taber wear results, is at:
Re metallurgy: The as-deposited EN is an amorphous, metallic alloy of Ni and between 1 & 13% Phosphorus (depending upon plating solution), most are 5-8.5% P.
The hardening mechanisms are the formation of NiP precipitates within the solid solution-hardened crystallizing coating matrix. See below:
"Deposit Stucture
Hypophosphite reduced electroless nickel is one of the very few metallic glasses used as an engineering material. Depending upon the bath formulation, deposits may contain from 1 to 13% phosphorus dissolved in nickel. The structure of these coatings depends upon their composition. Deposits containing more than 8.5% phosphorus have no crystalline structure or separate phases and are normally amorphous to x-rays. Deposits from 5 – 8.5% phosphorus contain different phases of nickel and are partly crystalline. Those deposits below 5% in phosphorus content and crystalline are typically laminar in structure...
For "Mechanical Properties" i.e., see
selected portions:
"Hardness & Wear Resistance
One of the most important properties for many applications is hardness. As deposited, The micro-hardness of electroless nickel coatings is about 500 to 700 HK100. That is approximately equal to 45 to 58 HRC and equivalent to many hardened alloy steels. Heat treatment causes these alloys to age harden and can produce hardness values as high as 1100 HK100. That is equal to most commercial hard chromium coatings...
Electroless nickel coatings have excellent resistance to wear and abrasion, both in the as-deposited and hardened conditions. Laboratory tests have shown fully hardened coatings to have wear resistance equal to hard chromium under both dry and lubricated conditions...
"Adhesion
The adhesion of electroless nickel coatings to most metals is excellent. The initial replacement reaction, which occurs with catalytic metals, together with the associated ability of the baths to remove submicroscopic soils, allows the deposit to establish metallic as well as mechanical bonds with the substrate. The bond strength of MacDermid EN coatings to properly cleaned steel has been found to be 400 MPa (60 kpsi) or more. The adhesion to aluminum and aluminum alloys is less, but usually exceeds 300 MPa (40 kpsi).
With non-catalytic or passive metals, such as stainless steel, an initial replacement reaction does not occur and adhesion is reduced. With proper pretreatment and activation, however, the bond strength of the coating normally is at least 140 MPa (20 kpsi). The adhesion to copper alloys is usually between 300 and 350 MPa (40 and 50 kpsi).
With metals such as aluminum it is common practice to bake parts after plating for 1 to 4 hours at 130 to 200 C (270 to 400 F) to increase the adhesion of the coating. These treatments stress relieve the part and the deposit and provide a very minor amount of codiffusion between the coating and substrate...
With regard to cyclic stress & sliding friction:
EN is very good w.r.t. sliding friction, there is lots of data for both dry & lubricated cases.
Re cyclic stresses, EN coatings should be very good in general up to the adhesion limit since EN is very strong and has little deposit stress, especially after heat treatment. ("The ultimate tensile strength of most coatings exceeds 700 MPa (100kpsi). That is equal to many hardened steels and allows the coating to withstand a considerable amount of abuse without damage."
However, there could be a problem in high strain situations, e.g., a thick EN deposit upon sheet metal which is severely bent, since the EN has limited ductility.
I should mention that the EN adhesion test for certifying to the various specs. is very severe: "4.5.2 Adhesion test. The test specimen shall be bent 180o over a mandrel [of] diameter 4 times the thickness (0.4 inch minimum) of the specimen..."[examine under magnification, try detaching with a sharp blade, then continue flexing 180 degrees until the substrate fails. the EN is allowed to fracture, but not to separate from the substrate, even with further use of a sharp blade]
