Harmonic dampers 5
yoshimitsuspeed
Automotive
Jan 5, 2011
191
I guess while I'm here I'll throw up another idea that's been on my mind. Pendulum style harmonic dampers.
There are a lot of solid crank pulleys out there. Often used to reduce weight. There is also a lot of good info out there that suggests it's not a great idea to use them because they can cause added stress, harmonics and on some motors even very rapid failure. Now all the 4 cylinders I deal with are naturally balanced so we don't have to worry about harmonic balancers like some motors do, just the harmonic dampening that helps prevent harmful frequencies from increasing to a dangerous point.
I am developing a pulley that has an integrated trigger wheel and I would like to use a solid pulley as it will be much cheaper to make. I have also read mixed reviews on polymer dampers especially when building high performance motors because from what I can tell they are designed primarily for one frequency range and from what I understand the harmful frequencies can change as you change things on a motor like displacement, horsepower, RPM, Boost, etc.
If I could get a pendulum style damper to work it seems like it would be pretty perfect for what I'm trying to do. I would assume that any weights would help dampen these frequencies but in that article they make it sound like it takes a specific design to work with different motors. It has me wondering if this is a huge issue or something they emphasize to scare people away from adopting it. My main question is whether it would be possible for a design like this to actually amplify frequencies if it was the wrong diameter or weight? Or would it just work less well?
Some day I would love to actually make a few designs and test them monitoring crank speed with a fine tooth trigger wheel or something but that won't be happening any time soon.
Do you guys have any thoughts on this? Would some weights even if not ideal be better than a solid pulley? Or could it be possible for the wrong design to actually be worse than a solid pulley?
Hi Yoshimitsuspeed,
I am by no means an expert in pendulum dampers, but I have played with them enough to know someone who is. You may want to contact Bill Brogdon at bmepinc. In addition to many other things, Bill oversaw design of the direct drive high compression ratio 4 cylinder boxer that propelled the aircraft "Voyager" around the world in 1984. The relatively low speed high bmep high cylinder pressure direct drive nature of aircraft engines create a TV nightmare, and the highest bmep aircraft engines almost exclusively employ pendulum dampers.
I don't know if Bill can add much to what EHudson has already said, as Bill will also refer to Den Hartog regularly. If you choose to contact him, his website address is:
bmepinc.com
Dick V.
Friction, viscous and (to a lesser extent) elastomeric dampers would all generate a lot of heat if the engine was continuously operated near a TV harmonic so it is not surprising that pendulum dampers would be favoured for aircraft engines.
je suis charlie
