tem1234
- Jun 13, 2007
- 192
Here is the case,
I measure harmonic with a power analyser at some motors and looking for the direction of the harmonics.
When i look at motor without drive or capacitor, the harmonics are going inflows, i.e. in the same direction of the fundamental. It's ok since motor and capacitor will not create harmonics, they'll just filter a little bit of them.
When i look at motor with drive, the harmonic are going mostly outflow, the drive are injecting harmonic in the network.
BUT... for some drive, harmonic are going inflow! Sometime all the harmonic are inflow, and other time only a couple are inflow. There a lot of other drives which are injecting harmonic in the network near theses drives.
So is it normal? Can a drive filter harmonic like this? or it is more like a bug of the power analyser? There's a drive (little compare to the other) which have 50% of 5th harmonic going inflow.
If you have a good reference on this phenomenal it would be very appreciate.
If you are asking how i determine the direction of the harmonic, look at "case study 12" of the attachement.
thanks
thanks
