A mechanical unit is being added over an existing roof structure. I went to site and found that the roof structure consisted of a 4" slab of concrete-like material (a little less dense) with what looks like a wire mesh at 6" spacing. The steel joists consisted of what looked like a single angle oriented as a "V" as a top chord. I was not able to confirm if there is a plate welded on top of the "V" nor was not able to see if there's some sort of connection between the slab and the existing roof slab. I also was not able to measure the thickness of the angle. The bottom chord is a plate with the web members as a rod. There was no steel deck found and the building is built in the 1950s. The existing joists are 18" DP at 4'-0" spacing.
Has anyone came across this type of structure in the past? What type of joists are these?
I would assume the top chord has some sort of connection to the concrete slab and is acting composite. Can anyone confirm this is the case for this type of joists?
Does anyone have an idea what type of material the slab is?
