My first idea was to make runner system that runs about 15 feet and elevation of about 7 feet. This leads to the pit on the lower level. However, I am not sure if the slag will make it that far. Whether it solidifies itself or having to high of viscousity and goes no where. I know if we are producing high carbon steel it does not flow as well, kind of like candle wax. On low carbon, I was told it flows similar honey. Also, we add a material called "Accutherm" to help the heat from being dissipated from the steel. This doesn't help the flow either. Yes, I am designing a replacement system. Thank you guys for you advice and comment.
