Has someone used the Samuel Bignardi's matlab software called OpenHVSR?
faigdavilaco
Geotechnical
Jun 8, 2023
I've been trying to use it but I need some explanation about it, has someone used it?
Zero reported open issues and only 1 pull request from someone other than the creator on Github.
That sort of suggests that yes, "someone" has used it, but not very many.
@IRstuff
Yes.
But, collaborators are almost certainly users. So, potential user count of collaborators = 1.
No issue reports. At all. 0 open, 0 closed.
Either this software is very very good, or there are few users to report bugs.
With that, I stand by my prior answer to the question asked.
I read de manual, but I can't understand how can I create my own file with my own data. Also, I'd seen you can use the design spectrum, but it doesn´t specify which format of it you should use. As well as other things, like how can I load a topography data on it.
