jonnythefox
Industrial
- Aug 21, 2014
- 8
Hello ,
I have a question regarding the New Hasco Reuse Library.
When I save an assembly file with a configurable Hasco part file from the reuse library it overwrites the itself to the saved configuration.Any other assemblies that use the same part will now have the same part file configuration.
I have tried editing the KRX file and used the "family member save" directory to save a different location. It does not seem to work. It always overwrites the part file in the reuse library.
The other reuse libraries I use do not behave like this. When I save the file it creates a part family member in a specified directory.
I have tried using the reuse Hasco Reuse Library in NX 10/11/12 . They all behave the same way for me.
Is there something I am overlooking?
Thanks for you help.
