ikkedus
- Dec 7, 2004
- 8
Hallo everybody,
When trying to create a drawing of a cast object i come across a problem.
The object is a part consisting of a revolved protrusion. Between the inner and outer diameter of the protrusion there are a couple of strengthening ribs (created with the rib command)
When i make a section view in the draft environment these ribs are hatched. I only want the solid body to be hatched and the ribs to be free of hatching. (as it should be acc. to drawing standards).
Anyone here knows a way to realise this?
greets,
Pascal
i already tried part copy to make the ribs as a seperate part. This didn't solve the problem because one cannot construct a rib on a construction body, and when i create a part copy as design body the ribs are hatched again.
greets,
Pascal
