Have engine moment of inertia, have generator moment of inertia, what is the combined moment?
tumbleweed1
44
We're driving a gen through a gearbox. I have the value of the engine moment and the generator moment. How would I calculate the combined value of moment of inertia for the genset?
Transmission ratio squared.
If engine runs at 3600 and generator at 1800, then Itotal is Ieng/i^2 + Igen, or Ieng/4 + Igen. If you look at it from engine side. From generator side it is Igen + Ieng*4.
Gunnar Englund
Yup, absolutely correct as usual.
Out of curiousity, do you have any 3600rpm engines driving 1800rpm generators through gearbox where you are?
I figure you probably just didn't give a lot of thought to numbers used for an example, but it did pique my interest.
(2B)+(2B)' ?
Ha, there is that. My point was gearbox to step a 2-pole speed down to 4-pole electrical generator speed (adds cost of gearbox and makes the generator more expensive to boot... no logical reason). But yeah, there's that 60/50 hz thing too ;-)
(2B)+(2B)' ?
Hi ePete,
The other possibility could be a large low speed engine and the gearbox is bringing the speed up to something more manageable and avoiding the use of a costly low speed generator. The nature of the question suggests that this isn't a small set and 3600 rpm is awfully fast for a large diesel engine. I have the feeling Gunnar picked the figures just to demonstrate a point, so we'll have to wait for the OP to add a bit more detail. :)
Ah interesting.
Our engine is 1500rpm gearbox to a gen spinning 1800rpm.
I received some info about the gearbox and coupling inertia values which is good. Would it be correct in thinking then:
Drivetrain is the following:
engine-coupling-gearbox-coupling-generator
where w is inertia constant...
[(Ew + Cw + Gw)*(1500/1800)^2] + Cw + Gw = Inertia seen at generator end
Correct?
Yup, that is correct assuming your analysis requires adding them together as a single total effective inertia seen at the generator.
That type model is probably good enough for questions of how long does it take to accelerate from 0 to full speed (with some specified torque characteristic specified for engine and effective torque on generator side factor of 1800/1500 higher).
I would think that other types of dynamic analyses such of finding system eigenfrequencies may require to model as multiple inertia's connected by torsional springs. Obviously a lot more involved.
(2B)+(2B)' ?
Questions, what power rating for the diesel engine and why 1500rpm, unless it is a large unit, if not- 1500rpm is a waste of hardware.
It's not possible to speed-up engine to 1800rpm (+20%) and remove gearbox?
Artisi- not a diesel, its a nat gas. Likely 1500 because it was built/designed in europe meant for 50Hz system.
iop95- No. Engine is designed and built for most efficient operation at 1500rpm. Yes theres some drivetrain losses but such is life.
