Hazen-Williams formula
Kristianx2
4
Q=4.03 x 10^-5 x D^2.65 x H^0.54
I would like to use this formula to size a water pipe (D). I have Q from flow requirements. How do I determine H? The pump is rated 50 m head. Distance of flow circa 1000 m.
What is the flow rate and can the pump produce the required flow rate at 50m head?
Carefull. Online flow loss calculators only determine straight pipe flow loss. You're talking about a system design with suction requirements, fittings, a valve or two and possibly some elevation change.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
Apakrat...thanks for the website. However, I still have two unknowns D & H (headloss). I need a way to calculate/estimate H.
You can start by assuming a pipe diameter that gives you a fluid velocity of 2 m/s.
If the pump is a centrifugal then you need to match the system and pump curves to see where they intersect. Basically, you calculate the head for a range of flowrates (or vice versa) and plot the calculated points to make the system curve on the same diagram as the pump curve.
See
Katmar Software
Engineering & Risk Analysis Software
