EdDantes
- Feb 22, 2008
- 3
I need to know if this setup will last a relatively small amount of cycles.
In the picture, you will see where a steel button [latch] locks into a mating part.
Typically, the mating part, is made of steel. We will say a heat treated carbon steel. Rc 20-30 (give or take). In this case, aluminum was chosen as a substitute for weight and corrosion advantages.
It appears in this photo that the steel button [latch] is locking into an anodized aluminum piece.
This will work but I have been told it will not stand up over time. For obvious reasons, like hardness of the different materials.
6061-T6 : 95 [Brinell]
4130 : 302 [Brinell]
We will use those 2 materials for argument's sake. The aluminum is correct. I am not 100% sure on the steel used.
Ok, so here is the break-down.
Steel button [latch] that is around 3 times harder than 6061-T6.
6061-T6 interface part. Hard Coat Anodized. Brings Rc up to 60-70.
Hinge pin made of stainless steel.
What problems are we looking at here ?
Accelerated galvanic corrosion ?
Accelerated wear ?
Others ?
How do we eliminate these problems ?
Link to picture :
Accelerated wear ?
Others ?
Link to picture :
