austsa
- Nov 24, 2011
- 107
HDPE pipe can be inserted into old underground steel or cast iron pipes used in water or gas distribution network, to save a total dig up and replacement. Other than checking of records, is there any other way of finding out whether a particular steel pipe has been inserted or not (eg say if some records are not 100% reliable)?
One way that I can think of is use a hot tap. If no water or gas is detected, then pipe has been inserted with HDPE pipe. But is there a better way?
Thanks in advance,
austsa
Thanks in advance,
austsa
