looking to plug a couple of HDPE pipes
[ul]
[li]first one is an abandoned 4" line that will be cut and plugged where it enters the ground[/li]
[li]second is used as a sleeve for two smaller lines and needs to be sealed at the end to prevent water or dirt entry.[/li]
[/ul]
I had originally thought that cement grout could be used, but with wide temperature swings / expansion and contraction of the pipe, it might not seal tight. I would like to avoid trying to use fused HDPE fittings. Is there another material that might work?
[ul]
[/ul]
