mariolucas75
Dear All,
Your opinion needed:
This is an elliptical horizontal vessel head-to-shell weld which developed a corrosion ~ m long.
Vessel thickness 15mm, corrosion allowance 3mm depth on marked location on photo is 5mm, rest of the pits are shallow.
What would be your opinion?
As per API:
"7.4.3 Evaluation of Pitting
During the current inspection, widely scattered pits may be ignored as long as all of the following are true:
a) the remaining thickness below the pit is greater than one-half the required thickness (½ t
required), and greater than 1.6 mm (0.062 in.);
b) the total area of the pitting deeper than the corrosion allowance does not exceed 45 cm2 (7 in.2) within any
20 cm (8 in.) diameter circle;
c) the sum of the pit diameters whose depths exceed the corrosion allowance along any straight 20 cm (8 in.)
line does not exceed 5 cm (2 in.)"
So would not it need an intervention / repair ?
But on the other hand - it follows the weld and looks as if some sort of "undercut" type corrosion ?
What would you advise ?
As per API:
