Hi There,
This is not a student question, it is a heat exchange that I have been designing in which I already know the physical size, material, etc of the heat exchanger but I would like to get an idea of what kind of temperature change I’m going to get by calculation rather than physical testing. I have been looking through my old text books from university but they only show examples of how to calculate efficiencies etc when all 4 temperatures are known. Not to mention my thermodynamics are a bit rusty.
I have simplified down the details as much as possible but I'm not sure exactly what I'm doing so I may be missing a few factors but that's why I posted it here. Please let me know if you need more information to answer this.
Basically I am trying to find out what would be my Q or t2 for the hot and cold side.
Hot Side Details
T1 = 40 degrees C
T2 = ?
Flow Rate = 0.142kg/s
C = 4180J/kgK
k = copper = 401 W/MK
x = 2mm
Area = 0.02M2
Cold Side Details
T1 = 15 degrees C
T2 = ?
Flow Rate = 0.0625kg/s
C = 4180J/kgK
x = 2mm
Area = 0.02M2
I guess I could always work backwards and put in some hypothetical temperatures but I figured this must be a fairly common exercise.
If anyone could give any help on how to find T2 or direct me to a similarly answered question that would be greatly appreciated.
Cheers,
Roy.
Hot Side Details
T1 = 40 degrees C
T2 = ?
C = 4180J/kgK
x = 2mm
Area = 0.02M2
Cold Side Details
T1 = 15 degrees C
T2 = ?
C = 4180J/kgK
x = 2mm
Area = 0.02M2
Cheers,
Roy.
