Hi All,
I've got a process stream at 390 deg C and wants to cool up to 38 deg C using cooling water at 29 deg C. I understand to limit the pipe wall temperature at a high process inlet temp. I have to cool/temper the process sream with air up to a certain temp and then intoduce into the H-E using cooling water.
Can somebody guide me as how to estimate the process inlet temperature which would not result in a high tube wall temperature.
Thanks in advance,
Asif Raza
Thanks in advance,
Asif Raza
