I wish to pressure test 2 heat exchangers (that have been in service for many years) to justify their suitability for continued service, and to avoid replacing them. These are simply tubes attached to a flange that inserts into the oil sump of a machine, and plant water passes through the tubes to an open drain. They certainly need cleaning, but I am not at all concerned with their heat exchange capacity, as that is well established. I only wish that they will not leak water into the reservoir. Does anyone know how much pressure constitutes an adequate pressure check of this type of heat exchanger?
