ChrisV82
- Dec 22, 2008
- 3
I am working on a project which requires a heat exchanger that can handle sea water on one side and deionized water on the other. Additionally, because of the application, no copper alloys can be used.
For deionized water only, I would typically use 316 stainless, but I believe the sea water will pose an issue to this material. I know brass is generally good for sea water, but this will be problematic for DI water, and as it contains copper, cannot be used. Titanium has been suggested, and seems to be a good fit, but is fairly expensive. Does anybody have any suggestions of other materials to look into? Thanks.
