My apologies if this is a simplistic question, but it's been a while since I've actually played with the numbers, mostly a management guy now.
The issue that I have is that I've been presented with a proposal that doesn't seem realistic.
150 ft of Tube-in-Tube heat exchanger:
Our product (Call it Gravy):
Flow Rate - 10 USGPM
T1 (Start Temp) 190 F
T2 (End Temp) 70 F
DeltaP - 150 PSIG
Spec gravity = 1.01
spec heat - c = 0.67 BTU/lb.F
thermal conductivity - k = 0.19 BTU/hr.ft.F
Viscosity - 14,856 cP (Centipoise) @ 127 F
Cooling Medium
50% Glycol, 50% Water
Flow Rate - 50 USGPM
T1 - 25 F
T2 - 48 F
Delta P - 21 PSIG
My question is simply, Is this realistic? The manufacturers claim that they can take the temperature from 190F to 70F seems to clash with my previous food product experience. I'm not confident that 150 ft of tube in tube can take this much heat out of a product.
Is this pressure change also realistic? I wish I still had my Thermo texts, it's frustrating that I can't figure this one out.
Thanks for any help.
T2 (End Temp) 70 F
DeltaP - 150 PSIG
Spec gravity = 1.01
Cooling Medium
T1 - 25 F
T2 - 48 F
Delta P - 21 PSIG
