I am researching on different types of diaphragm sealing technologies that are available for the heat exchangers. I did came across taper-lok pressure seal and reviewed its advantages over the welded diaphragms, however, the only material I came across was from the manufacturer.
Can someone please provide more detailed information on the types of sealing that are available for heat exchangers and comparative studies between the welded diaphragms and the pressures seals.
I am also looking for industry data or success results to compare which sealing technology is cost effective both in terms of maintenance and production.
