mildlyHVAC
- May 17, 2023
- 2
Hi all,
In Chapter 18 of ASHRAE Fundamentals 2021, we see this in the "Heat Gain From Fans" section (page 18.47):
"The power necessary at the input to the fan motor must account for fan motor inefficiencies and drive losses. Fan motor efficiencies generally vary from 80 to 95%, and drive losses for a belt drive are 3% of the fan power. This may be determined from
PM = (1 + DL) PF/(EMED)
where
PM = power required at input to motor, hp
ED = belt drive efficiency, dimensionless
EM = fan motor efficiency, dimensionless
Pf = power required at fan shaft, hp
DL = drive loss, dimensionless
Ok, so the question is, if as they say, "drive losses for a belt drive are 3% of the fan power"... does this mean for a belt-driven fan one sets DL=0.03? But if that is the case, isn't then using a value of ED < 1 also accounting for losses associated with the belt drive? I'm confused by the presence of DL and ED in this equation. Does anybody here know what's going on with this equation?
Appreciate any insights.
where
