Is it possible, with a heat pump, to do a Hot Gas Reheat, by diverting some of the Hot Gas from the Condensor to a reheat Coil. The goal is to respond to a call for dehumification without further cooling.
Please see attached diagram.
Equipment:
Heat Pump : (New-To Be supplied)3 Ton, 2 stage.
Controller : (Existing) Honeywell Vision Pro IAQ with dehumidifcation call capability.
Air Handler: (Existing) Custom built including plenum fan with VF Drive. The air flow can be varied.
Questions :
Can it be done ? or
Will this cause the heat pump to malfunction ?
Apart from the reheat coil, and 3-way valve, what other components would be required ?
Is there a manufacturer who manufactures such a Heat pump, ready for this of use.
What is the best way to execute such a design ?
Equipment:
Questions :
Can it be done ? or
