Heat Range of Ceramic Bodies
pyrosphere
Chemical
I need a source to document, from a scientific standpoint but without being too technically complicated, the fact that a vitreous stoneware body fired at cone 5 (approximately 2200 deg F) will remain unchanged when subjected to temperatures of 1000 deg F.
The best option would be to contact your stoneware supplier and ask for information on its properties at 1000F.
If you're mixing the clay yourself, or if this is a theoretical question, you may need to provide some more detail:
1) by "unchanged" are you referring to physical properties, microstructure, surface appearance, all of the above?
2) will the body be under some sort of load at 1000F, or in a particular atmosphere, or in contact with some other material?
3) Who is the audience for this document; how scientific should it be; what does it need to prove?
Adding to the above post knowing which material you are talking about would help immensely.
Your firing temperature is in the porcelain range and if it is porcelain there will be not discernible change at RT. Physical properties do however change while at 1000°F, like the Modulus of Rupture, thermal expansion, and thermal conductivity.
here are two sites with some information on fired vitreous
clays.
I was just wondering would viteous stoneware ever be used in an application that used its physical properties at a raised temperature other than perhaps thermal resistance.
Wouldn't an engineering ceramic be more appropriate?
