BronYrAur
- Nov 2, 2005
- 799
I am trying to understand some literature on Kohler Air compressors. I tried calling them, but got no where fast. Please take a quick look at the attachment from the specs on a 60kW, 60Hz unit.
My task is to ventilate the unit, but I don't fully understand the information. There is a "Cooling" section that discusses the radiator (which will be mounted directly to the unit). In that section, it lists "heat rejected to cooling water" as 3120 BTU/ min.
The next section on "Operation Requirements" lists "heat rejected to ambient air" as 1760 BTU/min for the engine and 440 BTU/min for the Alternator. What are these values? Are they in ADDITION to the radiator heat rejection? In other words, if I remove all the radiator heat, do I still need to remove this heat?
This same section of "Operation Requirements" shows that 6,000 scfm are required for "Radiator-cooled cooling air". What is this? Is it the CFM of the radiator fan? Or is it the additional CFM recommended for general room ventilation?
Thanks for your input.
