mpeck1982
- Nov 12, 2012
- 65
I have a water tubed boiler and I am trying to find out what is the temperature of my boiler water in the mud drum when it is on a cold stand-by operation... I have a carbon steel mud drum heating coil tubing with medium pressure steam of 140-lb at 390 deg F going into the mud drum. The boiler feed water and the main high pressure steam outlet is valved closed. The boiler water eventually settles to a certain temp after the heat transfer of the mud drum heating coil. Is there any kind of equation I can use to find out the resulting temperature of the boiler feed water from the heat transfer of the heating coil? The boiler water is stagnant in cold stand-by operation. Any help would be appreciated!!!
