Annelissenc.
Industrial
- Jan 31, 2023
- 9
Hello and thank you for having me in this forum.
I am trying to calculate the heat transfer coefficient of an open square etching tank containing 5000 L diluted 1% HF and 4% H3PO4 water solution. This tank has been immersed in a outer tank covered with tap water. The outer tank contains water, burner tubes and a cooling system to keep the temperatures between 41 and 46C. the inner tank is used to etch Aluminium and the by-products are aluminium fluoride and hydrogen. In a period of 5 weeks, the build up of aluminium fluoride in the inner tank can go up to 2500kg and creates a thick layer in the walls that works as an insulant reducing the efficiency of the temperature exchanges. Temperature goes above the etching limits (41-46C) and it is difficult to bring back down heating up to 50+C and taking 3+ hours to reach back operational temperatures. This is an issue that gets worse towards the end of the bath life (5 week old etching acid) and affects production speed.
I started an experiment where I am recording the temperatures of the inner and outer tanks before and after etching to see if over time the differential increases and I would like to be able to measure the heat transfer coefficient over the 5 weeks to experimentally see when and how this build-up is affecting the cooling and burning system efficiency. Can someone help? Suggestions and other approaches are welcomed
Materia Stainless still 316L grade
L =(Thickness ) = 3mm ( to be measured to confirm)
Iner tank leght = 1.900m
Iner tank with = 0.862m
Iner tank heigh = 1.903m
Inner tank A = 12.5m2
Cooling system uses Glycol as coolant
T1 and T2 experimentally
