tfry200
- Apr 13, 2009
- 18
I have a problem I'm trying to solve. I have a shaft that need to shrink fit a rotor onto. Due to the presence of seals inside the shaft, I have a maximum allowable temperature of 175F. I am trying to determine how close I will come to this temperature during assembly based of the cooled shaft and heated rotor. The shaft is solid. I have all the geometries, part masses, materials, etc.
I can do the basic equilibrium temperature calculation, but due to cooling via convection, the numbers come out high. I was just wondering if someone could get me pointed in the right direction to find a closer equilibrium temperature (maximum temperature the shaft will attain before it starts cooling). It's been a while since my heat transfer courses!
Here is my assumption:
One dimensional conduction
Composite Cylinder
Both materials steel (rotor is actually aluminum and steel, but steel makes up the majority of the exposed material and the rotor is fully heated to temperature)
Thanks for any help you guys can give.
Tim
Composite Cylinder
Tim
