canmecheng
- Feb 15, 2011
- 14
I have read quite a few posts regarding 4340 and 4140 so I apologize if this question has been asked before.
Do the strength properties in a large shafts (4" & 13" in diameters) vary through the thickness after Quench and temper heat treatment of 4140 and 4340. Would I see differences of hardness depending on the distance from the surface?
If so, would any strength specification be indicating average strength?
What is the best sequence to ensure I have proper strength in large shafts that require significant machining. For example, I have a 13" round, which half gets machined to 12.5" and the other half gets machined to 9.5" diameter. Would I rough machine, then heat treat such that the hardness suggests acceptable strength, in this caase 40HRC, then send a coupon sample for strength testing per A370. What diameter would the coupon be taken from? Then perform the final machining.
Are there any standards that specify the amount of machining that would be acceptable and still retain the strength values of the original raw material? For example if I have 43" rounds of A434-BD.
