Hi. Can anyone help with this heat treatment question?
As part of a heat treatment validation exercise I have measured hardness of materials following the recommended cycle
In the case of Custom 455 S/Steel, the Carpenters Data Sheet states that the maximum material strength is achieved by age-hardening to condition H900 (4 hours at 900oF and air cooled). A hardness of ~ 47-49 HRC is achieved at this condition.
However, I am measuring up to 57 HRC for some components
1)How has this happened? Could it be due to the temperature being too low?
2)If greater hardness than 47-49 HRC is achievable, why do Carpenters not recommend this as a standard cycle?
Additionally, I have experienced similar effects with Stainless Steel 17-4PH. Data sheets suggest that the maximum achievable hardness is 44 HRC, whereas I have measured up to 54 HRC (H900. 1 hour and air cooled).
Any help or explanation would be much appreciated.
Ian
Ian
