1
- #1
broeng
- Oct 22, 2015
- 3
How do you get the Draw Map Objects feature to work, specifically for the subbasin element?
I believe I correctly followed the "strict naming convention" (basinname_Subbasin) indicated in the User's Manual as the Draw Map Objects option under the View menu is selectable. When I select Draw Map Objects nothing is visible in the Basin Model screen. As a side note, the shape file I am attempting to use does display as a background map.
The only reason I want to use this feature is it is required for HMR-52 modeling.
