swazimatt
- Aug 19, 2009
- 267
thread789-447696
We have a wetland pond modelled to detain flow from the piped network for the 10year event and overland flows for the 100 year event. The catchment for the overland flow is different (smaller) to the 10 year pipe catchment. My stormwater engineer has informed me the level in the pond is lower for the 100 than the 10, which is obviously wrong. They have basically just run the 100yr with the 100yr catchment and ignored that the pipe network will still be directing flow to the pond. This is fine for the catchments that overlap, but we are missing a big portion of catchment that would still contribute flow through pipes at max flow (the balance runs overland to a different location)
the pipe network has been modelled on different software so there is no extensive pipe network in hec. Is there a way we can add the 10year pipe flow to the pond either as a constant flow or as a catchment with different rainfall?
I understand the pond hydrograph will be wrong, but we only need to check the max pond levels
Please bear in mind that i have only used HEC for 5 minutes so may not have described the HEC part 100% correctly but have a case of a junior engineer using hec telling me the software doesn't lie - which is true, but rubbish in rubbish out
We tried setting the pond height at the 10 year and adding the 100yr overland storm flow to it, but the 10yr levels drain before the 100yr storm peak arrives. This would also be a doubling of the piped flow for the overlap portion of 100 and pipe catchments but if it was still contained within the pond it would be a good conservative result
The next thing i was thinking of doing was to adjust the pipe only catchment area. eg if i have 1000m2 catchment and 100yr peak rainfall is 100mm/hr and 10yr is 80mm/hr could i just adjust the catchment to 800m2 and run it with the 100yr rainfall (probably not this easy)?
I think the simplest is to calculate the 10yr flow from the 10yr only catchment and add that to the pond as a constant base flow
