HEC HMS printout of results
JALeng
8
I am using HEC-HMS to model a watersheet. All is ok with the software until I want to printout the results. I tried several procedure encountered but not work. I found information on HEC webpage, but the information provided does not shown arranged procedure to make a printout of the results.
I will appreciate any information to help me ...
If you want a "report", you will have to create a style sheet using XML. They provide a sample one on the website, but it is pretty bare. When I use HEC-HMS, I just open the results window, like the Global Summary or a Time Series Table, and hit File --> Print. You end up getting a lot of individual sheets that you can assemble into a report. There is no out-of-the-box report tool, although I read that it is being considered for future releases.
Thanks mherr78, but is very difficult to prepare a report using these methodology.
